Remove multiple backups
What am I overlooking when trying to clean up the backups made by HA?
In System, backups my backups I have 493 backups 400 local on HA the others on my NAS.
I want to delete the 400 local backups as they no longer needed and old. Is there a way to select them and delete them in one go? I would not like to have the click them all and then select delete and then confirm delete!
As I could not find it a way to do this I deleted them from the backup folder manual, terminal backup dir then delete them.
I figured that when restarting HA the backup section would pick up on this and remove them from backup screen. Unfortunately not…
So how do I bring this back in sync without clicking 1200 times…
Thanks for the support.
Click the show all backups text then in the top bar to the right of the filters is an icon to make multiple select possible.
You might have to select every single one separately, if there is no select all option in the top bar, though.
I’m using the Samba share addon for that, easily work with the files in a filebrowser…
Thanks, Wally that does the trick :slight_smile:
