Running Hass.io 0.77.3 I have been trying to find out how to remove sensors that appear at the top of the frontend UI. I have some Qubino dimmers and some of the sensors that are detected are of no interest to me such as sourcenodeid, export etc. I have successfully excluded them from the history and recorder functions but can’t see a way to exclude them front the UI.
I have added the hidden parameter against their respective entries in the zwave_device_config.yaml file but this still has had no effect.
This doesn’t seem to work any more. I set an entity to not “Visible” via the UI and it just shows up in another section: “Sensor”, “Select”, “Switch”, and “Binary sensor” all show items for which I disabled “Visible”. The only way to hide them I have found is to hide all items without an Area, but that hides other things I don’t want to hide.
