Remove setup from Harmony Platform
I am seeing the below in my home assistant logs thoughts?
ERROR (MainThread) [homeassistant.components.remote] The harmony platform for the remote integration does not support platform setup. Please remove it from your config.
Any idea what I’m actually supposed to remove?
Harmony platform from the remote section in configuration.yaml
I’m also new to the HA and want to simulate what petro has discribed in his article but I get the same error on the configuration.yaml.
If the remote section needs to be removed from configuration.yaml, how do you then get the switches to work like in the xbox_one: example petro gave?
My harmony was discovered and created the harmony_16060911.conf file.
The switches are now automatically created but you can keep your originals. You just need to remove the remote section and add the integration from the ui.
The switches you speak of are in the template section.
Perfect, thanks. Got that part to work now. Up to the next steps, like controlling volume for a receiver that is only known on Harmony and channel selection for Telenet decoder. Preferably only showing when active.
