idowza
(Steven)
August 25, 2019, 11:20pm
1
I’m quite new to Home assistant, so this may be a relatively easy questions.
How do I remove the to decimal places from the end of the temperature gauge I have on the overview page?
I would like it to just display 74 F
I am using a Hue motion sensor (sensor.entry_motion_sensor_temperature)
Thanks!
Tinkerer
(aka DubhAd on GitHub)
August 26, 2019, 6:09am
2
Ideally you configure the sensor to only report whole numbers. Alternatively you build a template sensor to create the value you want:
sensors:
entry_temperature:
friendly_name: "Entry temperature"
unit_of_measurement: '°C'
value_template: "{{ states('sensor.entry_motion_sensor_temperature')|int }}"
nickrout
(Nick Rout)
August 26, 2019, 8:27am
3
Seems to me the sensor should report 75 if the usual rounding algorithm (the one I learned at school) is applied…
That would use round instead of int, so
value_template: "{{ states('sensor.entry_motion_sensor_temperature')|round }}"
Twit
(Simon)
August 26, 2019, 10:54am
4
I use a template sensor with both round and int - this works so yours will look like,
value_template: "{{ states('sensor.entry_motion_sensor_temperature') | round|int }}"
Simon
idowza
(Steven)
August 26, 2019, 1:31pm
5
Thanks everyone! it worked great!
Took me a while to realize that I had to select the new entity, but finally figured that out.
Sorry to bring back an old thread, but how would you go about specifying the number of decimal places to display?
I have a temperature sensor showing -1.500000C and I only want it to show -1.5C
I’d like the top reading to display similar to the bottom reading.
