is it possible to remove the side bar ? and / or modifying the menu ?
you know you can hide it…
Yeah tap on the hamburger icon at the top next to the side-bar…
As for removing, I don’t believe you can permanently remove it, but you can sure hide it. See the circled button:
As for modifying it, you can add to it, and remove some items.
For example that map, the second choice in your example, that’s there because you have map: in your configuration.yaml. Remove that if you don’t want to have access to the map. Same with the logbook because you have logbook: in your config.
To add things to this menu, take a look at documentation pages for panel_custom and panel_iframe, both linked below:
Thank you for your answers
@Silicon_Avatar you win
that’s what I want to do
I will try to modify the menu now.
Thank you
