So i have this motion sensor that is fed viad mqtt unto HA it delivers automatically the following
unit_of_measurement: ’ ’
this leads to the fact that a line chart is being generated which doesnt make sense for a binary motion sensor. i can override once in the dev>states area and remove unit of meassurement. however this is no permanent solution. this will give me the bar chart what i want to achive.
in customize i can only add/change unit of meassurement.
If it is mqtt you can ignore the discovered sensor on the integrations page then add a binary mqtt sensor manually using yaml. Use the device_class “motion”.
