Remove unused sensors from S31 Lite entity?
I just installed a couple of S31 Lite switches (Amazon screwed me and slipped in an S31 Lite listing when I was looking for S31 - didn’t notice until after I flashed them).
Everything works great, but in HA I have a whole slew of sensors that all display “0” because the S31 Lite doesn’t have those sensors. I set the profile on the switch itself for S31 Lite, but HA still picked up these non-existent sensors and I can’t delete them.
Is there a way to clean this up?
What did you flash them with? If ESPHome, you can just remove those non-existent sensors from the config and re-flash OTA.
If you are using the core Sonoff integration you can disable the entities in the Configuration / Integration / Sonoff / Entities list.
Tasmota
Been looking at ESPHome documentation this morning and thinking about changing, but haven’t decided if it’s worth the effort yet.
Can I do an OTA flash from Tasmota to ESPHome or do I have to take the whole thing apart and solder it again?
they’re disabled, but still showing up and logging “0”'s. I guess I can just not look at that and ignore it.
Yes, just pay attention to the note at the bottom, that on the sonoff’s console page, you’ll likely have to run “SetOption78 1”.
thanks! I have 2 S31 Lite’s. I think I’ll convert one to ESPHome and see what I like better.
