I want to remove the map, etc… from the left side. From what I read, I would need to remove the default_config line. But now that I did the regular pages dont load. What do I manually need to re-add so that it will work.
I just want to have the bottom options for the administrator, and the regular tabs for all other users.
I can add it back in. But how would I remove the maps, logbook, etc… From the left side. I am trying to keep it as simple as possible without somone being able to go to a different page.
Read the documentation and try to figure out how to do that,
There is no tutorial to customize HA exactly as you wish. The defaults are provided to give an easy start while permitting more advanced users to remove the defaults and customize to suit their preferences.
It does not yet appear you have reached that advanced level.
If you remove default_config you must replace it with all the options is represents, minus the one you don’t want (map).
Ideally there should be a way to use default_config but instruct it to exclude a few unwanted options. However, this capability doesn’t exist. If you think it should, please consider voting for this Feature Request:
