Removed deprecated forecast attribute from WeatherEntity
Hi, until now i was stuck for a while on core version 2023.12.4 and i had forecast weather sensor
- sensor:
    - name: "forecast_thermometer_temperature"
      unit_of_measurement: "°C"
      state: "{{state_attr('weather.tomorrow_io_home_daily','forecast')[0]['temperature']|round(1)}}"
How should i change it to make it work again. I see there is some service call needed, but can i still somehow use sensor template, or it must be approached in a completely different way?
Do i get it correctly that i can replace in templates.yaml
- sensor:
with something like that:
- trigger:
    - platform: time_pattern
      minutes: "0"
    - service: weather.get_forecasts
        entity_id: weather.tomorrow_io_home_daily
        type: daily
      response_variable: daily
    - name: Forecast temperature
      state: >
        {{ daily['weather.home'].forecast[0].temperature }}
or i should to remove my old entry from templates.yaml and add this new one in some other way?
I have added in templates.yaml following sensor, and it works:
- trigger:
      minutes: "0"
        type: daily
      state: >
        {{ daily['weather.tomorrow_io_home_daily'].forecast[0].temperature }}
    - name: Precipitation probability
      state: >
        {{ daily['weather.tomorrow_io_home_daily'].forecast[0].precipitation_probability }}
