Removed Z-wave device from controller but it's still in Home Assistant
Hi!
I’ve had some problems with one of my Z-wave devices and for some reason using the remove node function in home assistant didn’t work. Since my controller is a z-stick gen5 I have the option to exclude nodes manually by disconnecting the z-stick and holding the button on it for a few seconds to get it in exclude mode. Then I wake up my device (fibaro smoke detector in this case) and it is excluded. Done and done. Or so I thought. It still shows up as “Unknown node 11” in Home assistant. If I try to use “remove failed device” the z-wave log says the device ID is unknown. I’m guessing it really is excluded in the controller, but home assistant still has information saved about it somewhere. How do I get rid of that?
Always nice to solve something by oneself :slight_smile: I had to click the heal network button for z-wave. That sorted it out :slight_smile:
