I setup a couple of led strip type lights (WS2812B etc) for testing and i want to remove them now. Does anyone have any steps that they know works?
I’ve seen a few threads on here which i’ve tried but having no luck at all the lights seem to still show up in the Overview.
for the record i have tried:
stopping HA / editing them from any files in “.storage”
using MQTT-Explorer-0.2.6.exe + connecting and deleting.
nothing is in any of my groups / automation or configuration files.
any ideas?
Ok I’ll check the API out, if I wanted to stay in mqtt then anyone know what my options are? Or am I ready best to move to the API and away from mqtt ?
nickrout
(Nick Rout)
June 13, 2019, 10:09pm
4
I think you could just remove the mqtt as per those instructions I posted and then re-add them as mqtt.
But the api has some advantages, which are listed in the esphome docs. (same page, https://esphome.io/components/api.html#advantages-over-mqtt )
sathish
(Sathish)
October 20, 2019, 5:10am
5
HI, Can I control other ESPhome device with api?
sathish
(Sathish)
October 20, 2019, 5:13am
7
So, I have to use mqtt component to control other ESPhome device right? And other device also should have mqtt enabled right?
nickrout
(Nick Rout)
October 20, 2019, 7:06am
8
Why would you do this? Home assistant should be in charge, it is counter-productive to start putting little automations all over your house.
