Hi, I’ve just installed Home Assistant on my linux server, it has already found my google home mini and my Yeelight bulb, but I would like to remove the lamp directly from the configuration but without using ignore. Is it possible? Thanks.
I have to question that logic.
If you don’t ignore it, and exclude it from the discovery process, how would you expect it to know you don’t want it included in the discovery?
Also begs the question why you want to ignore it? Are you adding it manually as well? You can just use customise to hide it.
well, he specifically states he doesn’t want to ignore it…I’m thoroughly confused.
