I am not sure this is in the correct section or not but having issue where i had added some entities using the configuration.yaml while installing envisalink integration. Now I am not able to delete them? The configuration.yaml has been corrected to no longer show them and when i try and select them to remove in the entities tab it will not allow me to select them. How do I get those entities delete?
Delete the yaml.
Restart Home Assistant.
Delete any “Restored” entities from Settings → Devices & Services → Entities.
