I’m trying to remove the Logitech Harmony Integration due to a problem I’m having, however although it’s been removed from the integrations page I can see in the logs and in the system info that it is still trying to set up the integration.
Is there anything further I need to do to completely remove the integration?
Ah, it seems I’m not the only one having Harmony issues
In my case, the integration itself works fine, it’s the auto-discovery that caused issues.
I disabled the ssdp:
integration to workaround the issue.
Figured it out. Had to remove the entries in the .storage folder and then I could add it again.
