Removing unwanted entities - Flic
Hassio add-on flicd picked up three of my Flic’s that are supposed to be managed by my Flic Hub.
How do I delete them?
I can see them in states but cannot work out where they are stored and how to remove them.
Have you tried:
discovery:
  ignore:
   - flic
Not sure how this will help me. I use Flicd for some existing Flic buttons and Flic Hub for other.
I just want to remove them from hassio but unable to do so
Did you get to solve this? I have the same issue
I believe I had to edit them out of a database.
In the end it didn’t seem to work so I reinstalled it.
Yep that’s what I did… I reinstalled, linked only the flics that I wanted and then set discovery to false to avoid the rest of the flics to link to HA. Thanks anyways, there doesn’t seem to be an easy way
I know this is an old thread, but I’m struggling to remove some flic buttons I added in HA using flicd.
This is the only thread I found mentioning anything about removing them. deleted the add-on and installed it again, but I still see the unwanted buttons. Any hint on how you have deleted them from the DB?
I can’t remember completely but I believe I uninstalled the addon and removed the unwanted entities before reinstalling the addon. Then did what I explain in my last post. That made my flics disappear
