LukeC_UK
(Luke)
March 27, 2023, 11:45am
1
Hi All,
I’ve renamed some ESPhome devices, as I’ve re-purposed them.
They’ve been discovered as new ESPhome devices, which is fine, but they’ve also been discovered as Zigbee/ZHA devices. The hardware in question is connected via wifi, so this doesn’t make sense to me.
Has anyone else seen this before? Any ideas?
Regards,
Luke
Still there, after upgrading to 23.4, and rebooting plenty of times.
Does anybody have any ideas?
I still have the same issue.
Can anyone help?
tom_l
May 1, 2023, 1:14pm
5
That’s very strange. Can you share the config for one of your devices?
Hi Tom,
Thanks for moving this back to ESPhome. It started out here a while ago, I think
All four devices have similar config files, and all four are re-flashed Sonoff Mini R1s.
The config is based on the example Sonoff Mini config.
substitutions:
devicename: tube-heater-1
friendly_devicename: Tube Heater 1
api_key: ****
ota_password: ****
ap_password: ****
# devicename: sonoff-mini-1000b*****
# friendly_devicename: Sonoff Mini 1000b*****
esphome:
esp8266:
board: esp8285
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "${api_key}"
ota:
password: "${ota_password}"
wifi:
ssid: !secret wifi_ssid
# Remove or comment out use_address
# use_address: sonoff-mini-1000b****.local
ap:
ssid: "${devicename}"
password: "${ap_password}"
captive_portal:
- platform: wifi_signal
name: ${friendly_devicename} Wifi Signal Strength
update_interval: 60s
- platform: uptime
binary_sensor:
# the 7 lines below define the reset button
- platform: gpio
pin: GPIO00
internal: true # hides reset switch from HomeAssistant
filters:
- invert:
- delayed_off: 10ms
# the 3 lines below toggle the main relay on press of reset button
# on_press:
# - light.toggle:
# id: light_id
# the 13 lines below toggle the main relay on command
- platform: gpio
#internal: true # hides relay toggle from HomeAssistant
pin: GPIO04
filters:
- invert:
- delayed_on: 50ms
- delayed_off: 50ms
- delayed_on_off: 50ms
#on_press:
# then:
# - light.turn_on:
# id: light_id
#on_release:
# then:
# - light.turn_off:
# id: light_id
# the 2 lines below create a status entity in HomeAssistant.
- platform: status
status_led:
pin:
number: GPIO13
inverted: true
output:
# the 3 lines below control the main relay
- platform: gpio
pin: GPIO12
# the 3 lines below control the Blue LED
- platform: esp8266_pwm
pin: GPIO13
inverted: True
light:
# the 4 lines below define the main relay as a light
#- platform: binary
# name: "${friendly_devicename} Light" # you can enter a custom name to appear in HomeAsistant here.
# output: main_relay
# id: light_id
# the 4 lines below define the Blue LED light on Sonoff Mini, to expose in HomeAssistant remove line "internal: true"
- platform: monochromatic
name: "${devicename} blue LED"
output: blue_led
internal: true # hides the Blue LED from Homeassistant
switch:
- platform: output
name: "${friendly_devicename}" # you can enter a custom name to appear in HomeAsistant here.
output: main_relay
tom_l
May 1, 2023, 2:59pm
7
I have no idea why this is happening. Perhaps open a new issue here.
