I renamed my GE 14294 from the semi-unfriendly default node name when I added it to HA to “Basement Playroom Light”. I used the ZWave -> Rename Node menu. It’s now called "zwave.basement_playroom_light as the entity id.
I also had a device_config entry for it to change polling interval so it would update it’s status in a reasonable time.
Problem is now that I’ve renamed it HA doesn’t report it’s status correctly now. If I trigger it off on the card it turns off but the status toggle flips back to on. I have to trigger it again to show status off and then yet again to turn it back on after which it shows it on correctly.
Am I missing something obvious about changing the node name?
