Got a new installation of Hassbian 0.63.2. Starting on from scratch cleaning up my old installation. Got 30 Z-wave devices to configure though and im using a Aeon Z-Stick.
My problem is when renaming the node in entity_registry.yaml. Doing so renames the node but after that I’m not able to change its state from the UI. E.g. a Switch cant be switched from the UI. But when changing it’s state using its hardware it changes in the UI.
The entity registry has introduced some issues. You might also need to rename it using the control panel - but given the Z-Wave issues with 0.62 and now 0.63 I’ve not upgraded my own instance.
Probably you’ll need to raise an issue about this.
Renames the entity/node from Z-wave Configuration section in HA. Removes the old entity from entity_registry.yaml (or remove it completely if working from scratch).
