Rendering entity Info tab as a dashboard card
Is there a way to create a card on a dashboard which has the exact same contents as the Info tab of an entity (see example image)?
When I just use an entity / entities card it renders only a very limited subset of the options for this entity:
I know of custom media player cards out there, but Iā€™d like to know the answer to whether (and how) the Info tab for any general entity can be rendered as a card. If it cannot, why not?
Shortly after posting this I was able to finally come across a solution after quite a bit of searching.
Buy this man a coffee!
