Renew Let's Encrypt certificate
I’m trying to to renew the certificate with this command:
./letsencrypt-auto certonly --email [email protected] -d example.duckdns.org
but I’m getting the following error:
Installing Python packages...
Had a problem while installing Python packages.
pip prints the following errors:
Collecting argparse==1.4.0 (from -r /tmp/tmp.9WFX0MRGFv/letsencrypt-auto-requirements.txt (line 11))
  Downloading argparse-1.4.0-py2.py3-none-any.whl
Collecting pycparser==2.14 (from -r /tmp/tmp.9WFX0MRGFv/letsencrypt-auto-requirements.txt (line 17))
  Downloading pycparser-2.14.tar.gz (223kB)
Collecting cffi==1.4.2 (from -r /tmp/tmp.9WFX0MRGFv/letsencrypt-auto-requirements.txt (line 21))
  Downloading cffi-1.4.2.tar.gz (365kB)
    Complete output from command python setup.py egg_info:
    cc1: internal compiler error: Segmentation fault
    Please submit a full bug report,
    with preprocessed source if appropriate.
    See <file:///usr/share/doc/gcc-4.9/README.Bugs> for instructions.
        No working compiler found, or bogus compiler options
        passed to the compiler from Python's distutils module.
        See the error messages above.
        (If they are about -mno-fused-madd and you are on OS/X 10.8,
        see http://stackoverflow.com/questions/22313407/ .)
Command "python setup.py egg_info" failed with error code 1 in /tmp/pip-build-JqRwHZ/cffi
You are using pip version 8.0.3, however version 9.0.1 is available.
You should consider upgrading via the 'pip install --upgrade pip' command.
Certbot has problem setting up the virtual environment.
We were not be able to guess the right solution from your pip
output.
Consult https://certbot.eff.org/docs/install.html#problems-with-python-virtual-environment
for possible solutions.
You may also find some support resources at https://certbot.eff.org/support/ .
Any help?
Based on those two items I would start with updating PIP and run it again.
I tried it and the result is:
Requirement already up-to-date: pip in /usr/local/lib/python2.7/dist-packages
I tried also everything i found in the internet. I give up.
Have you tried running sudo apt-get update and then sudo apt-get upgrade? Looks like your dist packages need updated.
Also I found yesterday that if you are upgrading existing certs you only need to run
./letsencrypt-auto renew --email youremailaddres
It will automatically find your certs and your domain and update them.
Thank you for the support. Sadly, same error all the time.
I want to thank you all for the trip. I decided to move to a commercial product that all of this is out of the box. I spend to many time everyday in order to solve problems. SSL renewal, Restarts, Updates that broke working components, abandoned buggy components (LG WebOS) etc…
Dang, sorry to hear that. Good luck and best wishes.
And pip3 install --upgrade pip?
Did you try temporarily opening ports 80 and 443 on your router?
I managed to renew following the instructions
All renewal attempts failed. The following certs could not be renewed:
  /etc/letsencrypt/live/<redacted>.duckdns.org/fullchain.pem (failure)
1 renew failure(s), 0 parse failure(s)
IMPORTANT NOTES:
 - The following errors were reported by the server:
   Domain: <redacted>.duckdns.org
   Type:   unauthorized
   Detail: Incorrect validation certificate for tls-sni-01 challenge.
   Requested
   c3abfee05277410f095ad3af97f68750.fe79ef0da9725b48b540a45de8a493a6.acme.invalid
   from <redacted IP>:443. Received 2 certificate(s), first certificate
   had names "<redacted>.duckdns.org"
   To fix these errors, please make sure that your domain name was
   entered correctly and the DNS A record(s) for that domain
   contain(s) the right IP address.
I opened up port 80 just like I allways do.
Any idea what’s wrong?
I’m running home assistant ver 0.54 on a hassbian install. attempting to renew my certbot certs and having all of the issues documented thus far on this thread. Has anyone figured it out?
