a long time ago, i bought a Renpho Scale, last week i tried this scale to integrate in my HA System.
So i found the Custom Integration by neilzilla https://github.com/neilzilla/hass-renpho.
I installed it, but get no information from the Renpho Server.
I get this information in my log
It seems that the Server is not reachable, if i try to open, i get a 404 Error.
I´m trying to support the developer and solve the problem by myself.
With google, i have tried to find the right and reachable adress to a API, but i get no information for an API or an Information, that a API exist.
Is this still working. These are the endpoint of the old renpho app.
If the OP is using the new Renpho Health app with a relatively newly created user, I don’t think this rest endpoint still works.
I have a renpho scale from 2 years ago and when I switched to the new app, I can’t seem to get the measurements from this URL.
@BenjiMcKenzie, to confirm I’m understanding this topic correctly - this uses an ESP32, so I could use an existing one in the same room I keep the tape measure in and just add the vast majority of your ble_client and below .yaml onto it?
I also presume this is going into metric - would you happen to have a handy way to convert it to US measurements?
Thank you very much for this. I have copy-pasted your code to my configuration.yaml (to the last part) (I put my actual email and password, and changed from Susko to Jon - my actual name- )
But still, somehow it doesn’t work (I have the new Renpho app not the old one, I just bought a new scale thinking that it was Home Assistant compatible)
As shown, there I no weight recorded. Any hint on why?
