I want to add my Renson Sense on HA.
Anybody know if there are an integration ?
It’s not the same device.
I follow the instructions abd put IP and not nok
So i have looked at the traffic to / from the device and looks like there is API access.
http://SENSE_IP/v1/constellation/global
Gets a reply as an example in json response.
Does anyone have any documentation on this?
@ronandezyn maybe?
Hi Philip
The Renson Sense uses local communication for configuration but the API is not supported for 3rd party integration. We do have a cloud API but this is (for now) only available to large organizations (e.g. schools) for monitoring purposes. We plan to develop an API portal which will make it easier to enroll, enable and support API access but this for 2025 at earliest. I will ask our product manager for Renson Sense about the local API though. I will get back to you if I know more
All the best
Ronan
Thanks Ronan,
I’ve managed to sucessfully test the API get request using postman.
https://api.renson.eu/dataapp/app/SENSE/XXXXXXXX/home
XXXXXXXX = device serial number
for Auth you need to use the bearer token.
Keep you posted on progress on intergrating in HA
So quick update, bearer token does expire, im looking at a work around for this.
But i have mange to pull data using this method into HA and create a test dashboard.
Hi @ronandezyn is there anyway of getting the Api key / Auth of you guys? Looks like the SSL is pinned and thats a dragon quest i want to avoid if i can.
The local API for the Renson Sense is unfortunately not public and not supported so until this is the case we cannot support any integration for this product. I did however forward this topic to the product manager to consider for the road map. Apologies for the inconvenience
@ronandezyn bump, is there any movement on this? We would love to be able to connect our Renson Sense devices to HA!
Hi Philip, unfortunately not, we do have a cloud API which may be an alternative solution once we have our B2C onboarding process (and API portal) ready, I expect to know more once our 2025 planning has been finalized
I can help with this part, or have you already found a solution?
I have found a solution to bypass the API tokens. I’m new to Home Assistant, so I’ll look into how I can share this.
Edit:
i’ve sent you a message, thanks
I sent you a message, we love to get info on the work aro7nd.
any update on this integration? i have an Renson Sense Go and to be honest. not supporting 3rd party integration is a bit of a deal breaker. getting this information into HA would help a lot in my home automation
Hi @Mking, Thanks to @PatHA for the code,
I managed to get my Renson Sense working via a local Restful Get method.
Replace http://192.168.1.213 with the local IP of your Renson Sense.
You might need to rejig the order of the sensor elements.
/homeassistant/configuration.yaml
# RESTful sensor: Retrieves the full JSON data
- platform: rest
resource: http://192.168.1.213/v1/constellation/sensor
method: GET
json_attributes:
- "0" # Co2
- "1" # Lux
- "2" # Sound
- "3" # VOC
- "5" # Temperature
- "6" # Relative Humidity
- "8" # Heap
- "9" # RSSI (WiFi-signal)
value_template: "OK" # Placeholder because the data is processed via attributes.
scan_interval: 60 # Update every 60 seconden
template:
- sensor:
# CO2-Concentration
- name: "Renson CO2-Concentration"
unit_of_measurement: "ppm"
unique_id: "renson_co2"
state: >
{{ state_attr('sensor.renson', '0')['parameter']['concentration']['value'] }}
# Light
- name: "Renson light"
unit_of_measurement: ""
unique_id: "renson_lux"
state: >
{{ state_attr('sensor.renson', '1')['parameter']['lux']['value'] }}
# sound
- name: "Renson sound"
unique_id: "renson_sound"
state: >
{{ state_attr('sensor.renson', '2')['parameter']['average_level']['value'] }}
# VOC (Volatile Organic Compounds)
- name: "Renson VOC"
unique_id: "renson_voc"
state: >
{{ state_attr('sensor.renson', '3')['parameter']['raw']['value'] }}
# Temperature
- name: "Renson Temperature"
unit_of_measurement: "°C"
unique_id: "renson_temperature"
state: >
{{ state_attr('sensor.renson', '5')['parameter']['temperature']['value'] }}
# Relatieve humidity
- name: "Renson Humidity"
unit_of_measurement: "%"
unique_id: "renson_humidity"
state: >
{{ state_attr('sensor.renson', '6')['parameter']['humidity']['value'] }}
# Heap
- name: "Renson Heap "
unique_id: "renson_heap_average"
state: >
{{ state_attr('sensor.renson', '8')['parameter']['average_current_heap']['value'] }}
# RSSI (WiFi-signaalsterkte)
- name: "Renson RSSI"
unit_of_measurement: "dBm"
unique_id: "renson_rssi"
state: >
{{ state_attr('sensor.renson', '9')['parameter']['rssi']['value'] }}
# Uptime (apparaat up-time)
- name: "Renson Uptime"
unit_of_measurement: "s"
unique_id: "renson_uptime"
state: >
{{ state_attr('sensor.renson', '0')['parameter']['up_time']['value'] }}
First of all thanks for the effort, i think because this is an Sense go, it is not working.
I have used Postman to try to sent the JSON tot the URL but i did not get an reply back
i know for sure that i have the correct IP because when i turn de device of, and ping the IP adres, the respons is 0 and by turning it on, the respons is 32ms
