Hi all,
I am struggling to get any video feed with Frigate on Home Assistant on a raspberry pi 4. Here is my config file:
mqtt:
host: 192.168.xx.xx
port: 1883
user: frigate
password: password
cameras:
soffit:
ffmpeg:
inputs:
- path: rtsp://admin:[email protected]:554/h264Preview_01_sub
roles:
- detect
- record
log file from Frigate
023-11-25 21:17:24.553616049 [2023-11-25 14:17:24] watchdog.soffit ERROR : Ffmpeg process crashed unexpectedly for soffit.
2023-11-25 21:17:24.554765887 [2023-11-25 14:17:24] watchdog.soffit ERROR : The following ffmpeg logs include the last 100 lines prior to exit.
2023-11-25 21:17:24.562120726 [INFO] Service NGINX exited with code 256 (by signal 7)
2023-11-25 21:17:25.135709326 [2023-11-25 14:17:25] frigate.video ERROR : soffit: Unable to read frames from ffmpeg process.
2023-11-25 21:17:25.137068366 [2023-11-25 14:17:25] frigate.video ERROR : soffit: ffmpeg process is not running. exiting capture thread...
I tried making the config file as small as possible. I’m pretty sure the mqtt is working because if I intentionally have the wrong password I get an MQTT error. I also tried accessing the main and sub rtsp streams on the VLC viewer on my Win11 PC and those worked fine. (h265 for main, h264 for sub). I can also ping the camera from the console of my home assistant.
I tried the config file recommended for Reolink on the Frigate docs, but that gave me the same error.
The camera works fine with my reolink app. I also had it running with the Onvif integration until I intentionally disabled that in case it was causing issues with Frigate.
Thanks for the help!
