I have a Reolink camera in the kids room pointing outwards.
Can someone imagine a way for me to have a toggle buttton on the dashboard that gives me just the “audio feed” of the cam? I am trying to use it as a babyphone replacement basically… The full image feed requires fullscreen video to toggle on the audio… not what I want as it blocks everything else on my dashboard which I still want to see when the audio stream runs… Any ideas/examples? Thanks a ton from a new HA user!
How could this be done? Does anybody have experience with this or two-way audio in general?
Hi David, apparently there is no separate audio stream for those camera’s.
If used on a browser instead of the mobile app, you can open a new tab to stream that video and have the audio while using other tabs/windows.
If on mobile, you could install another app just for the camera.
I don’t think it is possible to achieve what you want with HA, but I might be wrong and someone else has a solution…
