Have you tried the HA MotionEye addon? I think it can do this, but haven’t tested it yet.
Hi, thanks for the hint. I ruled it out initially as it doesn’t work on iPhone. Will give it another try.
Edited the OP with the automation I have to use to get the snapshot from the E1 Pro, connection-wise for who can provide it a LAN cable I think it is now a much better choice than the Zoom.
Thanks but I personally prefer to have my camera in simple card. Besides, I noticed that I’m getting a few false positives, even lowering motion sensitivity, in particular when rotating the camera when alarm is armed/disarmed, therefore, an eventual entity becomes pretty much unreliable is the plan is to link it to the alarm system.
alias: Camera Alert - Voordeur
description: ''
- platform: device
device_id: e352c3cd58670490ad750b875318b72a
domain: nest
type: camera_person
condition: []
- service: notify.mobile_app_mobiel_dennis
message: Er staat iemand bij de voordeur
title: Camera Alert
image: /api/camera_proxy/camera.voordeur
mode: single
This is the way I did it @johnflorin , until I saw your post, which works also perfectly fine
Thanks for the info in this thread. Initially my Reolink E1 Pro image was unusable due to lag in the video stream. However, I tried the suggested webrtc and it works perfectly now. Here is my card:
- type: vertical-stack
cards:
- type: 'custom:webrtc-camera'
url: 'rtsp://admin:[email protected]:554//h264Preview_01_main'
# entity: camera.loungereolink_profile000_mainstream
- type: glance
entities:
- entity: camera.loungereolink_profile000_mainstream
icon: 'mdi:arrow-down-drop-circle-outline'
show_state: false
tap_action:
action: call-service
service: onvif.ptz
service_data:
entity_id: camera.loungereolink_profile000_mainstream
tilt: DOWN
move_mode: ContinuousMove
icon: 'mdi:arrow-up-drop-circle-outline'
show_state: false
tap_action:
service: onvif.ptz
service_data:
tilt: UP
icon: 'mdi:arrow-left-drop-circle-outline'
show_state: false
tap_action:
service: onvif.ptz
service_data:
pan: LEFT
icon: 'mdi:arrow-right-drop-circle-outline'
show_state: false
tap_action:
service: onvif.ptz
service_data:
pan: RIGHT
- type: glance
entities:
icon: 'mdi:wall'
show_state: false
tap_action:
service: onvif.ptz
service_data:
preset: '000'
move_mode: GotoPreset
icon: 'mdi:sofa'
show_state: false
tap_action:
service: onvif.ptz
service_data:
preset: '001'
Are you using webrtc? I had the same problem as you until I changed to that.
No, it is with HA ONVIF integration. I had previously unstable work of WebRtc integration and difficulties with https access to it.
What code do you use to generate the snapshot, can you show us? Also, you’re sure the camera is not moving during/near the moment the snapshot is being generated?
How webrtc can help to make snapshot? I just can show live video, isn’t it?
camera variable contains camera entity_id:
- service: notify.me
title: "Camera"
message: "Photo"
photo:
- url: >
http://192.168.1.23:8123{{ state_attr(camera,'entity_picture') }}
Even if I see the picture via browser with such url I see corrupted picture.
This is how I do it, taking a pic first and then sending it, can you see if this works for you?
I got MotionEye fully working for motion detection & notifications today, so I edited the guide for anyone who also wants this functionality
Is there any command to make the camera zoom?
What integration did you use for it? ONVIF?
Thank you for this procedure.
I wanted to try this E1 camera but unfortunately it seems that both ONVIF and RTSP are not available.
I tried adding it on VLC, Surveillance Station, HA Onvif Integration, but none of them can connect.
Reolink apps (desktop and mobile) are working well, but that’s it.
I don’t understand what I did wrong, maybe someone has an idea ?
Note: I did not even tried to shut down outgoing connections yet (usually, this is where things start to not working anymore, but I’m not even there !)
Do you have the E1 or the E1 Zoom or E1 Pro? This guide is not for the E1, unfortunately.
