Reolink Failed to connect
I have RLC-810A camera and it gets detected. On configure I enter user and pass and I get this error:
any idea what could be wrong? In the logs I see:
2023-05-09 22:35:28.559 ERROR (MainThread) [reolink_aio.api] Host 192.168.0.19:443: API error: API returned HTTP status ERROR code 500/Internal Server Error.
Exactly the same issue here, works on the app but can’t get it into HA. Did you find a solution since?
I have this with my Reolink Floodlight device only, cameras are setup just fine.
Any thoughts/solution in the meantime?
It started to work then, I don’t remember what I did. Maybe next release of HA fixed it,
I’m still getting this issue…
Did you just input your NVR IP address? no port number and unticked enable HTTPS?
any update on this? I have the same issue.
Does the Reolink Floodlight model (sans camera) actually integrate wth HA?
It doesn’t appear in the list of supported devices (at time of post).
I’d love to get a few if I know it works
I am having this same error trying to connect the Home Hub. No combination is working. I have the IP address, no HTTPS, and no port.
I’m having the same issue, has anyone found a solution as to why this is happening? I have upgraded the firmware on the NVR and Cameras. I have made sure that all the ports needed are open, and I’m still getting the same error.
I have the same issue both with the reolink integration and the hacs integration.
The regular integration hangs after putting in the IP and credentials to the NVR and then it gives a generic error.
The hacs integration discovery never finds it.
I do have HA on a different subnet VLAN then my reoink NVR.
I’m looking at setting up a UDP broadcast helper on my firewall for udp/3000…
Not sure if that’s going to resolve it.
Anyone have any luck with getting real link NVR or it’s attached cameras into HA?
Still a problem. I just tried to connect my new Argus PT camera and connect via the app, but HA errors out.
Having the same issue with my 511w
This issue still exists. At least in my HA.
Anybody found a solution?
