Reolink integration - Push Notification
Hi All,
I’ve installed new Reolink Camera (RLC-811A & RLC-833A).
I want to enable Push notification when Alarm is armed. The automation is ready but I found that Push notification is not working with this plugin.
Does someone have Reolink Camera linked with HA ?
When I go to the device setting the Push Notification Toggle is available but changing it to Enabled or Disabled has no effect to the camera. When trying with another option (Recording) it working fine
Thank you for your suggestion
Run different debugs and seem that it used this API command GetPushV20 / SetPushV20
Found this interesting topic
You cannot get the state on Mobile or Web Interface but this global Switch is working as expected :wink:
I invite you to see how the push functionnality works between the API one and the Smartphone one :
Go the the end of the post.
Regards
Has the error been resolved since then?
Did you manage to turn on/off PUSH notifications from HomeAssistant?
Push is again not working, on no camera… i have different cameras like Lumus Pro, E1 Zoom, RLC-840WA. My cameras connected with home hub pro. The other function i testet are working via home assistant. Is it possible to apply a configured scene from the home hub? Then i dont need to configure the scenes again in home assistant and i have no problems with the push entity. But it would be also nice when the push entity would work.
Hello. Has somebody solved this issue in 2025 ? Or in this case where we can open a bug - is it HA problem or Reolink problem ? Thank you
Hello, I want to enable or disable recording, flashlight and push notifications via script (for Android Widget).
Everything works except push notifications.
The switch in this integration does nothing.
For this, I still have to change it in the Reolink App.
