So i’m having trouble with the reolink integration and i’m not sure where the right place to ask so here i am.
The integration works just fine for me execpt on the e1 pro devices. the device is found, polled and the entities are pulled in just fine, but if i try to look at the video stream i get the following error. it looks like it is expecting a port number but there is nowhere to put the port number.
“Failed to start WebRTC stream: webrtc: streams: parse “rtsp://admin:*******@192.168.0.64:None/Preview_01_sub”: invalid port “:None” after host, exec/rtsp [rtsp @ 0x7ff0aab90000] method DESCRIBE failed: 404 Not Found [in#0 @ 0x7ff0aae12b00] Error opening input: Server returned 404 Not Found Error opening input file rtsp://127.0.0.1:18554/camera.living_room_fluent?audio&source=ffmpeg:camera.living_room_fluent%23audio%3Dopus%23query%3Dlog_level%3Ddebug&log_level=debug. Error opening input files: Server returned 404 Not Found” I know it should be port 554 and that it does work because i can connect to it via frigate. Does anyone know what a fix might be or can point me in the right direction? Much appreciated.
-D
Port numbers are often given with URLs like www.hostnane.com:portnumber
