Reolink Siren in Apple Home
Hi
I tried to bring my flashlight and sirens from the reelink camera over home assistant in Apple home. The floodlight works fine but I’m not able to add the siren. My yaml looks the following:
  include_entities:
    - light.eingang_unten_floodlight
    - light.ptz_ost_terrasse_floodlight
    - light.haupteingang_floodlight
    - light.sued_terrasse_floodlight
    - siren.haupteingang_siren
The entity is correct, I copied it similar the name from the floodlight.
Does anyone have an idea what’s wrong here?
Thanks & best Regards
Stefan
Solved: It was the wrong entity. Right is:
switch.haupteingang_siren_on_event
Regards,
Stefan
Good you got it solved!
Please take the time to mark your post as the solution, you do that by selecting the three dots under the post:
Then select the check box:
By doing so this prevents that someone else steps in to try to help.
Hi
Unfortunately not solved. The switch is in my home app, but doesn’t work. Is there anyone who added the siren button successfully to apple home?
Regards,
Stefan
