Reolink Video Doorbell with standard chime connected with an esphome device
I have created an esphome device that rings my existing chime that is triggered when somebody pushes the Reolink video doorbell. The hardware is based on an esp8266 (d2 mini). This device is connected using D2 to a relay. The relay triggers the chime.
The device is triggered by an automation that publishes an mqtt message. Only an On message is send. The chime turns itself off.
alias: Doorbel on
description: ""
  - type: turned_on
  platform: device
  device_id: xxx
  entity_id: binary_sensor.reolink_video_doorbell_poe_visitor
  domain: binary_sensor
condition: []
  - service: mqtt.publish
      qos: "2"
      retain: false
      topic: doorchime/button
      payload: "On"
mode: single
The Esphome is code is below.
The chime automatically turn off after a programmable delay.
I have replaced some of the keys with ā€œ***ā€ that were generated when the device was created.
esphome:
  friendly_name: Doorchime
esp8266:
    board: d1_mini
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Doorchime Fallback Hotspot"
    password: "***"
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "***"
ota:
  password: "***"
mqtt:
  broker: mqttbroker
  birth_message:
    topic: doorchime/status
    payload: online
  will_message:
    payload: offline
time:
  - platform: homeassistant
text_sensor:
  - platform: version
    name: Chime ESPHome Version
  - platform: wifi_info
    ip_address:
    ssid:
    bssid:
  - platform: mqtt_subscribe
    on_value:
      then:
        - lambda: |-
            ESP_LOGD("main", "Received doorbell request: %s", x.c_str());
            if (strcmp(x.c_str(), "On") == 0) {
              ESP_LOGD("main", "Turn doorbell ON");
              if (id(chime_active).state)
                 id(relay).turn_on();
              else
                ESP_LOGD("main", "The doorbell is not active");
            } else {
              ESP_LOGD("main", "Turn doorbell OFF");
              id(relay).turn_off();
  - platform: uptime
  - platform: wifi_signal
    name: Chime WiFi Signal
    update_interval: 60s
globals:
  - id: chime
    type: bool
    restore_value: true
    initial_value: 'true'
switch:
  - platform: gpio
    pin:
      number: GPIO05 #D1
      inverted: true
#    internal: true
    icon: mdi:alarm-bell
    on_turn_on:
      - delay: 200ms
      - switch.turn_off: relay
  - platform: restart
    restore_state: false
    turn_on_action:
      - globals.set:
          value: 'true'
    turn_off_action:
      - globals.set:
          value: 'false'
    lambda: |-
      return id(chime);
Hi, Can you post a diagram or describe in detail how the D1 Mini relay is connected to your chime and/or transformer. I’m trying to do something similar. Thanks.
Here is a picture of the d1 mini and the relay
The relay gets power from the d1 mini and one output of the d1 is connected to the relay.
