So I’ve been racking my head on this one and figured I’d start here to get some feedback.
Here’s my set up:
(6) Reolink E1Pro WiFi cameras
(1) Synology RT2600AC router
(2) Synology MRC2200 access points
WebRTC Camera integration
Home Assistant 2022.12.8
Supervisor 2022.12.1
Operating System 9.4
HA running on an Intel Small PC
All of my cameras, Wi-Fi works perfectly fine as-is. I can view the cameras in the Reolink app perfectly. Wi-Fi is smooth, no issues.
I added the WebRTC integration to HA and was able to add the RTSP feeds to my cameras to my dashboard, but whenever they load up, they “crash” my Wi-Fi mesh network, meaning all of my mesh access points start disconnecting and reconnecting to my main router.
The only way to stop it is to restart HA.
For now I’ve completely removed the Web RTC integration as well as cleared the cameras from my dashboard.
Part of me thinks it has to do with the 6 Reolink cameras trying to connect (via 5Ghz) at the same time to display the RTSP streams and maybe that’s crashing the network?
Just trying to see if anyone else has had the same or similar issue or if anyone has any recommendations to a better way to integrate and display the Reolink cameras?
T.I.A.
Edit: Forgot to upload this screenshot of my Wi-Fi logs which shows the issue
