With every reboot I’m getting the “Reolink webhook URL unreachable”-error and I don’t know what I should change.
The error:
Did not receive initial ONVIF state from Voordeur. Most likely, the Reolink camera can not reach the current (local) Home Assistant URL
http://10.25.10.25:8123
, please configure a (local) HTTP address under “Home Assistant URL” in the network settings that points to Home Assistant. For examplehttp://192.168.1.10:8123
where192.168.1.10
is the IP of the Home Assistant device. Also, make sure the Reolink camera can reach that URL. Using fast motion/AI state polling until the first ONVIF push is received.
The information instructs me to set the Home Assistant URL, but I’ve already set it:
The camera integration doesn’t work either after the reboot, but when I restart the Integration it’ll show the camera feeds. I’m running the latest version of HA:
Home Assistant 2023.7.3
Supervisor 2023.07.1
Operating System 10.3
Frontend 20230705.1 - latest
My Reolink DUO PoE is running the latest version
Firmware Version v3.0.0.1388_22100600
Any suggestion/help would be much appreciated.
