I have been having an annoying issue with my Reolink Wifi doorbell. I am using the official integration and am using a handful of automations for motion and visitor sensors however each time the connection goes down temporarily (usually once every other day or so) when it come back up the sensors will no longer work. The camera feed and everything shows as normal however sensors will not come though. I have to go into the device in HA and reconfigure before it will start picking up again.
After reading several posts on here I turned off RTMP, RTSP, HTTPS in the reolink settings (therefore I am only using HTTP), set my protocol in HA to FLV, and also made sure in HA network settings that the local network is pointing to the actual IP of my HA instance. Doing this made it a little more stable but no matter what if the device disconnects at any time the sensors will no longer work.
Reolink firmware: Firmware: v3.0.0.3308_2407315182
HA 2024.10.4 Docker installation
