Under “Configuration -> General” please move the “Configuration validation”, “Configuration reloading”, and “Server management” to the top of page.
“Name”, “Timezone”, “Elevation” and “Unit System” are currently at the top. Since these are either set once and don’t change, or not used and set in configuration.yaml, it doesn’t make sense having them at the top so have to scroll down to get to the frequently used sections.
I just came here to request this exact thing. The things at the top are ‘set and forget’ for the vast majority of users. They might as well be at the bottom of the page.
this has been discussed several times elsewhere. Supposedly the devs were having a discussion on how to handle it. I haven’t heard what the final determination was but it was is still like that in the newest release so maybe that’s the answer?
hopefully this feature request will get their attention and it will be addressed.
I hope they see this. Having to scroll down every time gets old fast. In the mean time I made a small script to just move the 2 cards down. Idk why the HTML doesn’t seem to have any IDs or class names for it’s elements, but oh well. I use a Chrome extension called InjectCode to inject it every time the page is open.
if (location.pathname == '/config/core') {
var header = document.querySelector("body > home-assistant").shadowRoot.querySelector("home-assistant-main").shadowRoot.querySelector("app-drawer-layout > partial-panel-resolver > ha-panel-config > ha-config-core").shadowRoot.querySelector("hass-subpage > div > ha-config-section-core").shadowRoot.querySelector("ha-config-section > span:nth-child(1)").innerText;
var nameCard = document.querySelector("body > home-assistant").shadowRoot.querySelector("home-assistant-main").shadowRoot.querySelector("app-drawer-layout > partial-panel-resolver > ha-panel-config > ha-config-core").shadowRoot.querySelector("hass-subpage > div > ha-config-section-core").shadowRoot.querySelector("ha-config-section > ha-config-name-form");
var mapCard = document.querySelector("body > home-assistant").shadowRoot.querySelector("home-assistant-main").shadowRoot.querySelector("app-drawer-layout > partial-panel-resolver > ha-panel-config > ha-config-core").shadowRoot.querySelector("hass-subpage > div > ha-config-section-core").shadowRoot.querySelector("ha-config-section > ha-config-core-form");
var resetCard = document.querySelector("body > home-assistant").shadowRoot.querySelector("home-assistant-main").shadowRoot.querySelector("app-drawer-layout > partial-panel-resolver > ha-panel-config > ha-config-core").shadowRoot.querySelector("hass-subpage > div > ha-config-section-core").shadowRoot.querySelector("ha-config-section > ha-card:nth-child(8)");
function insertAfter(el, referenceNode) {
referenceNode.parentNode.insertBefore(el, referenceNode.nextSibling);
if (header == 'Configuration and Server Control') {
insertAfter(mapCard, resetCard);
insertAfter(nameCard, resetCard);
