Repair line YAML configuration has moved - help with code
Hi All,
I’ve got myself in a pickle with the update to 2023.6.1 and my YAML.
I get an error “Repair Line YAML Configuration has moved” but no further details when I click on it (it shows up as a repair on settings page.
The original code I had was:
- platform: command_line
 command: "python3 /config/pyscripts/get_agile_incoming_ordered.py"
 scan_interval: 315360000
 value_template: '{{value_json.Run_number1}}'
 json_attributes:
   - Run_number1
   - Run_number2
   - Run_number3
   - Run_number4
   - Run_number5
   - Run_number6
   - Run_number7
   - Run_number8
   - Run_number9
   - Run_number10
   - cost_number1
   - cost_number2
   - cost_number3
   - cost_number4
   - cost_number5
   - cost_number6
   - cost_number7
   - cost_number8
   - cost_number9
   - cost_number10
   - start_time1
   - start_time2
   - start_time3
   - start_time4
   - start_time5
   - start_time6
   - start_time7
   - start_time8
   - start_time9
   - start_time10
   - end_time1
   - end_time2
   - end_time3
   - end_time4
   - end_time5
   - end_time6
   - end_time7
   - end_time8
   - end_time9
   - end_time10
   - min_rate1
   - max_rate1
   - mean_rate1
 unique_id: octagrangeinord1
notify:
 - name: "Give_Charge"
   platform: smtp
   server: "smtp.gmail.com"
   port: 587
   timeout: 15
   sender: !secret email_sender
   encryption: starttls
   username: !secret email_user
   password: !secret email_password
   recipient:
     - "[email protected]"
   sender_name: "Inverter"
And I tried to change to to command_line as I understood it in the new command_line help page as:
command_line:
  json_attributes:
    - Run_number1
    - Run_number2
    - Run_number3
    - Run_number4
    - Run_number5
    - Run_number6
    - Run_number7
    - Run_number8
    - Run_number9
    - Run_number10
    - cost_number1
    - cost_number2
    - cost_number3
    - cost_number4
    - cost_number5
    - cost_number6
    - cost_number7
    - cost_number8
    - cost_number9
    - cost_number10
    - start_time1
    - start_time2
    - start_time3
    - start_time4
    - start_time5
    - start_time6
    - start_time7
    - start_time8
    - start_time9
    - start_time10
    - end_time1
    - end_time2
    - end_time3
    - end_time4
    - end_time5
    - end_time6
    - end_time7
    - end_time8
    - end_time9
    - end_time10
    - min_rate1
    - max_rate1
    - mean_rate1
  notify:
      platform: smtp
      port: 587
      timeout: 15
      recipient:
Can someone explain to me what I have done wrong so I can understand it for next time?
For ref, there are other bits in the configuration.yaml, but if I remove this section, the file passes validation, with it in, it fails.
Error I get when validating configuration is :
Invalid config for [command_line]: [command] is an invalid option for [command_line]. Check: command_line->command_line->0->command. (See /config/configuration.yaml, line 24).
command_line:
  - sensor:
      command: etc...
You overlooked to include the sensor key in your configuration of the Command Line sensor.
command_line:
  - sensor:
      json_attributes:
        - Run_number1
        - Run_number2
        - etc etc
In addition, you put the configuration for an SMTP Notification entity under the command_line: key. Move it out of there.
EDIT
Ninja’d by tom_l
Thanks both! Looking again at the documentation it clearly showed the -sensor: that I missed!
@123 if i understand you correctly, the notification bit should be “Outside” of the command_line section?
Correct. Simply shift those lines to the left by two spaces.
So now it looks like this:
command_line:
  - sensor:
      json_attributes:
        - Run_number1
        - Run_number2
        - Run_number3
        - Run_number4
        - Run_number5
        - Run_number6
        - Run_number7
        - Run_number8
        - Run_number9
        - Run_number10
        - cost_number1
        - cost_number2
        - cost_number3
        - cost_number4
        - cost_number5
        - cost_number6
        - cost_number7
        - cost_number8
        - cost_number9
        - cost_number10
        - start_time1
        - start_time2
        - start_time3
        - start_time4
        - start_time5
        - start_time6
        - start_time7
        - start_time8
        - start_time9
        - start_time10
        - end_time1
        - end_time2
        - end_time3
        - end_time4
        - end_time5
        - end_time6
        - end_time7
        - end_time8
        - end_time9
        - end_time10
        - min_rate1
        - max_rate1
        - mean_rate1
notify:
    platform: smtp
    port: 587
    timeout: 15
    recipient:
which is no longer throwing errors! thanks both!
