Repeat 433Mhz commandline
I have some commandline switches to control 433mhz outlets. Most of the time it works but sometimes the signal won’t switch them. That’s because there is no feedback. It is possible to repeat the commands 2 or more times to be sure that the outlets has switched or is there a better way to controller such binary 433mhz switches?
My configuration is:
  • platform: command_line
    switches:
    weihnachtsbaum:
    command_on: send 11101 2 1
    command_off: send 11101 2 0
    couchlicht:
    command_on: send 11101 1 1
    command_off: send 11101 1 0
cant find such function. i wont do a script for every single switch. that is a huge amount of code.
And recognized that the switches do not switch when they are in a group, everything else works. but i think switching a group is to fast for sending this codes to the outlets… any Idea?
the only thing i can think of is to make a custom switch for that.
or use appdaemon to automate it.
i took the demo switch and made a custom switch like this:
Demo platform that has two fake switches.
For more details about this platform, please refer to the documentation
https://home-assistant.io/components/demo/
import logging
import voluptuous as vol
from homeassistant.components.switch import (
    ENTITY_ID_FORMAT, SwitchDevice, PLATFORM_SCHEMA)
from homeassistant.const import (
    ATTR_FRIENDLY_NAME, CONF_VALUE_TEMPLATE, STATE_OFF, STATE_ON,
    ATTR_ENTITY_ID, MATCH_ALL, CONF_SWITCHES)
from homeassistant.helpers.entity import generate_entity_id
import homeassistant.helpers.config_validation as cv
_LOGGER = logging.getLogger(__name__)
ON_CODE = 'on_code'
OFF_CODE = 'off_code'
SEND_SWITCH = 'send_switch'
SWITCH_SCHEMA = vol.Schema({
    vol.Optional(ATTR_FRIENDLY_NAME): cv.string,
    vol.Required(ON_CODE): cv.string,
    vol.Required(OFF_CODE): cv.string,
    vol.Required(SEND_SWITCH): cv.entity_ids
PLATFORM_SCHEMA = PLATFORM_SCHEMA.extend({
    vol.Required(CONF_SWITCHES): vol.Schema({cv.slug: SWITCH_SCHEMA}),
# pylint: disable=unused-argument
def setup_platform(hass, config, add_devices, discovery_info=None):
    """Setup the demo switches."""
    switches = []
    for device, device_config in config[CONF_SWITCHES].items():
        friendly_name = device_config.get(ATTR_FRIENDLY_NAME, device)
        on_code = device_config.get(ON_CODE, device)
        off_code = device_config.get(OFF_CODE,device)
        send_switch = device_config.get(SEND_SWITCH,device)
        switches.append(DemoSwitch(hass, device, friendly_name, False, None, False,send_switch,on_code,off_code))
    add_devices(switches)
class DemoSwitch(SwitchDevice):
    """Representation of a demo switch."""
    def __init__(self, hass, device_id, friendly_name, state, icon, assumed,send_switch,on_code,off_code):
        """Initialize the Demo switch."""
        self.hass = hass
        self.entity_id = generate_entity_id(ENTITY_ID_FORMAT, device_id, hass=hass)
        self._name = friendly_name
        self._state = state
        self._icon = icon
        self._assumed = assumed
        self._sendswitch = send_switch
        self._on_code = on_code
        self._off_code = off_code
    @property
    def should_poll(self):
        """No polling needed for a demo switch."""
        return False
    @property
    def name(self):
        """Return the name of the device if any."""
        return self._name
    @property
    def icon(self):
        """Return the icon to use for device if any."""
        return self._icon
    @property
    def sendswitch(self):
        return self._sendswitch
    @property
    def on_code(self):
        return self._on_code
    @property
    def off_code(self):
        return self._off_code
    @property
    def assumed_state(self):
        """Return if the state is based on assumptions."""
        return self._assumed
    @property
    def is_on(self):
        """Return true if switch is on."""
        return self._state
    def turn_on(self, **kwargs):
        """Turn the switch on."""
        self._state = True
        data = {"V_IR_SEND":self._on_code,ATTR_ENTITY_ID: self._sendswitch}
        self.hass.services.call("switch", "mysensors_send_ir_code", data)
        self.update_ha_state()
    def turn_off(self, **kwargs):
        """Turn the device off."""
        self._state = False
        data = {"V_IR_SEND":self._off_code,ATTR_ENTITY_ID: self._sendswitch}
now my mysensors 433 mhz remote is reached and in the yaml i have:
  - platform: demo
    switches:
      eraamhoek:
        friendly_name: Raamhoek
        send_switch: switch.afstandbediening_40_1
        on_code: 5570581
        off_code: 5570580
      epchoek:
        friendly_name: PC hoek
        on_code: 5586965
        off_code: 5586964
      ewandmeubel:
        friendly_name: Wandmeubel
        on_code: 5574677
        off_code: 5574676
that can be changed for every service. all that really needs to be changed is the def turn_on and turn_off.
at that place could be a sleep 1 second and send again.
does this works with intertechno/ELRO and their binary DIP-switches like 11100001?
It is possible to use the elro switches with binarycode with an arduino/nodemcu
you can do it with mysensors like i did.
If you dont have arduino and/or dont want to use mysensors ,it is also possible to do it on a pi itself. There is info about that elsewhere on the forum
