Repeat Alerts via app until acknowledged
I have setup my washing machine to alert me then the clothes are done and it comes across the home assistant app on my phone. I further set it up that I have it change the state from ‘clean’ to ‘idle’ once I click on the notification which allows me to acknowledge it.
The question I have, how can I set it up to keep alerting me that the clothes need to be taken out of the washer if I haven’t acknowledged the notification yet?
Here is a screenshot of my config for it:
Thanks.
Have the appropriate washing machine state trigger an input boolean to turn on. Have an automation that runs every X minutes until the boolean is turned off.
Example from a medication reminder I use.
#                MEDICATION REMINDER                    #
- alias: "Morning Medication Reminder"
    - platform: time
      at: "06:30:00"
  condition:
    - condition: state
      entity_id: input_boolean.medication_reminder
      state: "on"
    - alias: "Repeat the sequence UNTIL the conditions are true"
      repeat:
        sequence:
          - service: notify.mobile_app_adams_iphone
              title: "Medication Reminder"
              message: "Take your Medication!"
                tag: "medication-reminder"
                actions:
                  - action: SNOOZE
                    title: Snooze
                  - action: TAKEN
                    title: Taken
          - delay:
              minutes: 10
        until:
          - condition: state
            state: "off"
#             TURN OFF MEDICATION REMINDER              #
- alias: "Turn off Medication Reminder"
    - platform: event
      event_type: mobile_app_notification_action
      event_data:
        action: "TAKEN"
    - platform: time
      at: "00:00:00"
    - service: input_boolean.turn_off
    - delay:
        minutes: 15
#            END OF CONFIGURATION FILE                  #
There’s an integration for that…
So I tried to take everyone’s suggestions and have gotten it to the point where I rewrote the config and have put in an input boolean, but have tried ways then to repeat notifications if not answered and it still only sends it out once.
Here is my latest config:
- alias: Set washing machine active when power detected
  - platform: numeric_state
    entity_id: sensor.washing_machine_current_consumption
    above: 4
  condition:
    condition: or
    conditions:
    - condition: state
      entity_id: sensor.washing_machine_status
      state: Idle
    - condition: state
      state: Clean
    - condition: state
      state: Finishing
  - service: input_select.select_option
      entity_id: input_select.washing_machine_status
      option: Running
- alias: Set washing machine finished when power drops
    below: 4
  condition:
    condition: and
    conditions:
    - condition: state
      state: Running
      option: Finishing
- id: 2cfd9911671b4a7aabca572de88ebd19
  alias: Set washing machine clean after timeout
  - platform: state
    entity_id:
    - input_select.washing_machine_status
    to: Finishing
    for:
      hours: 0
      minutes: 3
      seconds: 0
  condition:
  - condition: and
    conditions:
    - condition: state
      state: Finishing
      option: Clean
  mode: single
- id: '1664915357105'
  alias: Notify - Washing Machine Finished
  description: ''
  - platform: state
    entity_id:
    to: Clean
  condition:
  - condition: and
    conditions:
    - condition: state
      state: Clean
  - service: notify.notify
      title: Washing Machine Done
      message: Remove the clothes
        tag: washing
        actions:
        - action: MACHINE_EMPTIED
          title: It's done
    data: {}
      entity_id: input_boolean.washing_machine_emptied
  mode: single
- id: '1665423737462'
  alias: Notify - Washing Machine Emptied Action
  description: ''
  - platform: event
    event_data:
  condition: []
      message: clear_notification
        tag: washing
    data: {}
      option: Idle
  mode: single
You don’t have a repeat for your notification service call…
  - alias: "Repeat notification as long as the Boolean is On"
    repeat:
      while:
        - condition: state
          state: "on"
      sequence:
        - service: notify.YOUR_ACTUAL_NOTIFIER
              tag: washing
              actions:
                title: It's done
        - delay: "00:00:30"
Also make sure you specify the actual notification service you want to use, do not use notify.notify… it may give you unpredictable results.
Drew,
Thank you, it seems to be working now. I only have 2 questions:
  1. how can I get it to send the initial alert for when it the clothes are done and then have it go every 15 minutes after the initial notification?
  2. What is wrong with using notify.notify? I have no problem changing it, just curious as to what kind of instability it could cause.
Thanks.
