I’m trying to automate my covers. I have no sensors to measure the cover position. Instead, i want to use a timer script to simulate the position of the cover. I configuerd a input_number as sensor to simulate the position. I made a script that executes when a switch is pushed or activated with the cover buttons on the dashboard.
The function of the script is simple. When a relay is activated to open or close, the sensor will decrement or increment every 500milliseconds and this in a repeat untill loop. This works all fine but when the sensor reaches 0 or 100, the script does not go to the next line witch is to stop the cover.
When i check the trace of the script, the last line is not excecuted and if i check the information button on that page, the script is still running.
There are no logbookentries that indicate for an error.
What do i miss here ?
The script was made with the visual editor.
alias: Timing cover
sequence:
- alias: Repeat until poscover >99 of < 1
repeat:
sequence:
- delay:
hours: 0
minutes: 0
seconds: 0
milliseconds: 500
- alias: Increment bij relay2_2 on
if:
- condition: state
entity_id: input_boolean.relay2_2
state: "on"
then:
- service: input_number.increment
entity_id:
- input_number.poscover
data: {}
- alias: Decrement bij relay2_1 on
if:
- condition: state
entity_id: input_boolean.relay2_1
state: "on"
then:
- service: input_number.decrement
entity_id:
data: {}
until:
- condition: numeric_state
entity_id: input_number.poscover
above: 99
below: 1
enabled: true
- service: cover.stop_cover
metadata: {}
data: {}
entity_id: cover.cover_bedroom
mode: restart
