Hi thanks for blueprint…
I have imported succesfully and create the animation as you suggested… it starts… but won’t cycle for colour change.
I have just replaced the entity input_boolean.test_toggle with my rgb bulb id.
From trace it seems that no if condition is matched after the first run (after 5 seconds)
"trace": {
"last_step": "action/2/if/condition/1",
"run_id": "9ef4b4e909b3e0dd72e415e2a76fb675",
"state": "stopped",
"script_execution": "finished",
"timestamp": {
"start": "2023-12-28T11:15:06.297103+00:00",
"finish": "2023-12-28T11:15:06.300177+00:00"
"domain": "automation",
"item_id": "1703760612682",
"trigger": "state of light.smart_rgb_bulb_2304123204813952050848e1e9c43242_none",
"trace": {
"trigger/2": [
"path": "trigger/2",
"timestamp": "2023-12-28T11:15:06.297250+00:00",
"changed_variables": {
"this": {
"entity_id": "automation.xmas_lamp_light_v3_0",
"state": "on",
"attributes": {
"id": "1703760612682",
"last_triggered": "2023-12-28T11:15:00.091027+00:00",
"mode": "single",
"current": 0,
"friendly_name": "XMAS Lamp Light V3.0"
"last_changed": "2023-12-28T11:13:31.465068+00:00",
"last_updated": "2023-12-28T11:15:00.496311+00:00",
"context": {
"id": "01HJR24ZVTFRWRYW1RJH9W84ED",
"parent_id": null,
"user_id": null
"trigger": {
"id": "Change Interval",
"idx": "2",
"alias": null,
"platform": "state",
"entity_id": "light.smart_rgb_bulb_2304123204813952050848e1e9c43242_none",
"from_state": {
"state": "off",
"attributes": {
"min_color_temp_kelvin": 2695,
"max_color_temp_kelvin": 6535,
"min_mireds": 153,
"max_mireds": 371,
"supported_color_modes": [
"color_temp",
"rgb"
"color_mode": null,
"brightness": null,
"color_temp_kelvin": null,
"color_temp": null,
"hs_color": null,
"rgb_color": null,
"xy_color": null,
"togglex_mode": null,
"icon": "mdi:coach-lamp-variant",
"friendly_name": "Smart Bulb None",
"supported_features": 0
"last_changed": "2023-12-28T11:08:26.848952+00:00",
"last_updated": "2023-12-28T11:08:26.848952+00:00",
"context": {
"id": "01HJR1RZGGQYE6804HQBATY4BW",
"parent_id": null,
"user_id": "3d68936c685f480f9cda400b4ed43f0a"
"to_state": {
"state": "on",
"attributes": {
"min_mireds": 153,
"max_mireds": 371,
"color_temp",
"rgb"
"color_mode": "rgb",
"brightness": 255,
"color_temp": null,
"hs_color": [
0,
100
"rgb_color": [
255,
0,
0
"xy_color": [
0.701,
0.299
"last_changed": "2023-12-28T11:15:01.293920+00:00",
"last_updated": "2023-12-28T11:15:01.293920+00:00",
"context": {
"parent_id": null,
"user_id": null
"for": {
"__type": "<class 'datetime.timedelta'>",
"total_seconds": 5
"attribute": null,
"description": "state of light.smart_rgb_bulb_2304123204813952050848e1e9c43242_none"
"action/0": [
"path": "action/0",
"timestamp": "2023-12-28T11:15:06.298507+00:00",
"context": {
"id": "01HJR255XS2J25422A93DPZ5JY",
"parent_id": "01HJR24ZVTFRWRYW1RJH9W84ED",
"user_id": null
"action/0/if": [
"path": "action/0/if",
"timestamp": "2023-12-28T11:15:06.298581+00:00",
"result": {
"result": false
"action/0/if/condition/0": [
"path": "action/0/if/condition/0",
"timestamp": "2023-12-28T11:15:06.298608+00:00",
"result": {
"result": false
"action/1": [
"path": "action/1",
"timestamp": "2023-12-28T11:15:06.298669+00:00"
"action/1/if": [
"path": "action/1/if",
"timestamp": "2023-12-28T11:15:06.298699+00:00",
"result": {
"result": false
"action/1/if/condition/0": [
"path": "action/1/if/condition/0",
"timestamp": "2023-12-28T11:15:06.298717+00:00",
"result": {
"result": false
"action/2": [
"path": "action/2",
"timestamp": "2023-12-28T11:15:06.298759+00:00"
"action/2/if": [
"path": "action/2/if",
"timestamp": "2023-12-28T11:15:06.298785+00:00",
"result": {
"result": null
"action/2/if/condition/0": [
"path": "action/2/if/condition/0",
"timestamp": "2023-12-28T11:15:06.298802+00:00",
"result": {
"result": true
"action/2/if/condition/1": [
"path": "action/2/if/condition/1",
"timestamp": "2023-12-28T11:15:06.298824+00:00",
"error": "In 'time' condition: unknown 'after' entity input_datetime.test_start_time"
"config": {
"mode": "single",
"trigger": [
"platform": "time",
"at": "12:15:00",
"id": "Start Time"
"platform": "time",
"at": "02:30:00",
"id": "End Time"
"entity_id": [
"input_select.color_vector",
"for": {
"hours": 0,
"minutes": 0,
"seconds": 5
"condition": [],
"action": [
"if": [
"condition": "trigger",
"id": [
"Start Time"
"then": [
"service": "light.turn_on",
"target": {
"entity_id": [
"data": {
"rgb_color": "{{ states('input_select.color_vector') }}",
"brightness": 255
"if": [
"id": [
"End Time"
"then": [
"service": "light.turn_off",
"target": {
"entity_id": [
"data": {}
"if": [
"id": [
"Change Interval",
"Start Time"
"condition": "time",
"after": "input_datetime.test_start_time",
"before": "input_datetime.test_end_time"
"then": [
"service": "input_select.select_next",
"target": {
"entity_id": "input_select.color_vector"
"data": {
"cycle": true
"target": {
"data": {
"brightness": 255
"alias": "XMAS Lamp Light V3.0",
"description": ""
"blueprint_inputs": {
"description": "",
"use_blueprint": {
"path": "samuelthng/ad_hoc_scheduled_interval.yaml",
"input": {
"start_time": "12:15:00",
"start_action": [
"target": {
"entity_id": [
"data": {
"brightness": 255
"end_time": "02:30:00",
"end_action": [
"target": {
"entity_id": [
"data": {}
"interval_entity": [
"interval_action": [
"target": {
"data": {
"cycle": true
"target": {
"data": {
"brightness": 255
"context": {
"user_id": null
"logbookEntries": [
"name": "XMAS Lamp Light V3.0",
"message": "triggered by state of light.smart_rgb_bulb_2304123204813952050848e1e9c43242_none",
"source": "state of light.smart_rgb_bulb_2304123204813952050848e1e9c43242_none",
"context_id": "01HJR255XS2J25422A93DPZ5JY",
"when": 1703762106.297359,
