Hi all,
my homeassistant installation on a Raspberry Pi 4 4GB / SD Card is crashing every couple of days. Seems the OS continues to run though, as it is not rebooting. Deconz (running via supervisor) also stops working, so my entire light setup stops working.
I found two other threads but no solution (Memory exhausted by python3 process - process/container crash - #5 by basnijholt) (HA repeatedly crashing every few hours, suspected memory leak - #2 by gmoney)
I added logging of RAM, CPU, Swap usage and also a persistent log for errors. Before crash RAM is at ~25% and nothing exceptional in CPU or Swap either. I get an MemoryError which is logged as Error and I see some problem with Deconz in the regular log:
Error log:
06:43 2021-12-14 ERROR [homeassistant] Error doing job: Task exception was never retrieved Traceback (most recent call last):
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 197, in async_init
flow, result = await task
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 224, in _async_init
result = await self._async_handle_step(flow, flow.init_step, data, init_done)
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 320, in _async_handle_step
result: FlowResult = await getattr(flow, method)(user_input)
File "/config/custom_components/bosch_shc/config_flow.py", line 198, in async_step_zeroconf
self.info = await self._get_info(host)
File "/config/custom_components/bosch_shc/config_flow.py", line 232, in _get_info
return await self.hass.async_add_executor_job(
File "/usr/local/lib/python3.9/concurrent/futures/thread.py", line 52, in run
File "/config/custom_components/bosch_shc/config_flow.py", line 73, in get_info_from_host
information = session.mdns_info()
File "/usr/local/lib/python3.9/site-packages/boschshcpy/session.py", line 277, in mdns_info
return SHCInformation(
File "/usr/local/lib/python3.9/site-packages/boschshcpy/information.py", line 80, in __init__
self.get_unique_id(zeroconf)
File "/usr/local/lib/python3.9/site-packages/boschshcpy/information.py", line 134, in get_unique_id
self._listener = SHCListener(zeroconf, self.filter)
File "/usr/local/lib/python3.9/site-packages/boschshcpy/information.py", line 32, in __init__
ServiceBrowser(zeroconf, "_http._tcp.local.", handlers=[self.service_update])
File "/usr/local/lib/python3.9/site-packages/zeroconf/_services/browser.py", line 516, in __init__
self.start()
File "/usr/local/lib/python3.9/threading.py", line 892, in start
_start_new_thread(self._bootstrap, ())
RuntimeError: can't start new thread
06:48 2021-12-14 ERROR [root] Uncaught thread exception Traceback (most recent call last):
File "/usr/local/lib/python3.9/threading.py", line 973, in _bootstrap_inner
self.run()
File "/usr/local/lib/python3.9/threading.py", line 910, in run
self._target(*self._args, **self._kwargs)
File "/usr/src/homeassistant/homeassistant/components/stream/__init__.py", line 284, in _run_worker
stream_worker(
File "/usr/src/homeassistant/homeassistant/components/stream/worker.py", line 489, in stream_worker
segment_buffer.mux_packet(packet)
File "/usr/src/homeassistant/homeassistant/components/stream/worker.py", line 175, in mux_packet
self.flush(packet, last_part=True)
File "/usr/src/homeassistant/homeassistant/components/stream/worker.py", line 236, in flush
self._av_output.close()
File "av/container/output.pyx", line 197, in av.container.output.OutputContainer.close
File "av/container/output.pyx", line 23, in av.container.output.close_output
File "av/container/core.pyx", line 258, in av.container.core.Container.err_check
File "av/error.pyx", line 323, in av.error.err_check
File "av/container/pyio.pyx", line 38, in av.container.pyio.pyio_write_gil
MemoryError
07:18 2021-12-14 ERROR [homeassistant] Error doing job: Fatal read error on socket transport Traceback (most recent call last):
File "/usr/local/lib/python3.9/asyncio/selector_events.py", line 856, in _read_ready__data_received
data = self._sock.recv(self.max_size)
MemoryError
MemoryError
homeassistant.log:
2021-12-14 07:17:59 INFO (MainThread) [homeassistant.components.automation.flutlicht_eingang_an] Flutlicht Eingang an: Running automation actions
2021-12-14 07:17:59 INFO (MainThread) [homeassistant.components.automation.flutlicht_eingang_an] Flutlicht Eingang an: Executing step device automation
2021-12-14 07:18:06 ERROR (MainThread) [homeassistant] Error doing job: Fatal read error on socket transport
MemoryError
2021-12-14 07:18:06 INFO (MainThread) [pydeconz.websocket] Reconnecting to deCONZ (core-deconz)
2021-12-14 07:18:06 INFO (MainThread) [homeassistant.components.automation.write_persistent_log] write persistent log error: Running automation actions
2021-12-14 07:18:06 INFO (MainThread) [homeassistant.components.automation.write_persistent_log] write persistent log error: Executing step call service
MemoryError
2021-12-14 07:18:06 INFO (MainThread) [pydeconz.websocket] Reconnecting to deCONZ (core-deconz) failed, scheduling retry at an interval of 15 seconds
So I am a bit lost as to what could be the problem. Maybe deconz is failing or consuming too much memory? But wouldn’t this show in system RAM usage?
I hope someone can help.
Thanks in advance.
Daniel
