Repeated status updates in tasmota console
Not sure if this is the right place for this, but on all of my sonoff devices, i have the following log appearing every 5-15 seconds. (some of the data varies obviously)
10:03:05 MQT: stat/RF_Bridge/STATUS = {“Status”:{“Module”:25,“FriendlyName”:[“RF_Bridge”],“Topic”:“RF_Bridge”,“ButtonTopic”:“0”,“Power”:0,“PowerOnState”:3,“LedState”:1,“SaveData”:1,“SaveState”:1,“SwitchTopic”:“0”,“SwitchMode”:[0,0,0,0,0,0,0,0],“ButtonRetain”:0,“SwitchRetain”:0,“SensorRetain”:0,“PowerRetain”:0}}
10:03:05 MQT: stat/RF_Bridge/STATUS1 = {“StatusPRM”:{“Baudrate”:19200,“GroupTopic”:“sonoffs”,“OtaUrl”:“http://thehackbox.org/tasmota/release/sonoff.bin",“RestartReason”:"Power on”,“Uptime”:“0T01:26:25”,“StartupUTC”:“2018-12-07T07:36:40”,“Sleep”:100,“BootCount”:636,“SaveCount”:647,“SaveAddress”:“F5000”}}
10:03:05 MQT: stat/RF_Bridge/STATUS2 = {“StatusFWR”:{“Version”:“6.3.0”,“BuildDateTime”:“2018-10-30T17:33:53”,“Boot”:6,“Core”:“2_3_0”,“SDK”:“1.5.3(aec24ac9)”}}
10:03:05 MQT: stat/RF_Bridge/STATUS3 = {“StatusLOG”:{“SerialLog”:2,“WebLog”:2,“SysLog”:0,“LogHost”:"",“LogPort”:514,“SSId”:[“MyWIFISSID”,""],“TelePeriod”:300,“SetOption”:[“00008009”,“55818000”,“00000000”]}}
10:03:05 MQT: stat/RF_Bridge/STATUS4 = {“StatusMEM”:{“ProgramSize”:489,“Free”:512,“Heap”:14,“ProgramFlashSize”:1024,“FlashSize”:1024,“FlashMode”:3,“Features”:[“00000809”,“0FDAE794”,“000183A0”,“23B617CE”,“00003BC0”]}}
10:03:05 MQT: stat/RF_Bridge/STATUS5 = {“StatusNET”:{“Hostname”:“RF_Bridge”,“IPAddress”:“192.168.12.20”,“Gateway”:“192.168.12.254”,“Subnetmask”:“255.255.255.0”,“DNSServer”:“8.8.8.8”,“Mac”:“60:01:94:A3:49:32”,“Webserver”:2,“WifiConfig”:5}}
10:03:05 MQT: stat/RF_Bridge/STATUS6 = {“StatusMQT”:{“MqttHost”:“192.168.12.201”,“MqttPort”:1883,“MqttClientMask”:“RF_Bridge”,“MqttClient”:“RF_Bridge”,“MqttUser”:“homeassistant”,“MqttType”:1,“MAX_PACKET_SIZE”:1000,“KEEPALIVE”:15}}
10:03:05 MQT: stat/RF_Bridge/STATUS7 = {“StatusTIM”:{“UTC”:“Fri Dec 07 09:03:05 2018”,“Local”:“Fri Dec 07 10:03:05 2018”,“StartDST”:“Sun Mar 25 02:00:00 2018”,“EndDST”:“Sun Oct 28 03:00:00 2018”,“Timezone”:1,“Sunrise”:“08:29”,“Sunset”:“16:53”}}
10:03:05 MQT: stat/RF_Bridge/STATUS10 = {“StatusSNS”:{“Time”:“2018-12-07T10:03:05”}}
10:03:05 MQT: stat/RF_Bridge/STATUS11 = {“StatusSTS”:{“Time”:“2018-12-07T10:03:05”,“Uptime”:“0T01:26:25”,“Vcc”:3.182,“Wifi”:{“AP”:1,“SSId”:“MyWIFISSID”,“BSSId”:“xx:xx:xx:xx:xx:45”,“Channel”:6,“RSSI”:92}}}
Any idea how i go about stopping these messages? I assume that weblog 0 would do it, but i use TasmoAdmin that gives me a message to say that it expect a response with weblog2.
The Logging on each of them is set to 2|2|0
Thanks in advance
Do you have the tasmoadmin addon enabled?
in home assistant? No i’m using it as a separate docker. If i use weblog 0 then the constant updates stop on the console, but they also do not report to tasmoadmin.
Yeah ok. In docker is the same thing.
This is how tasmoadmin talks to your devices. You either put up with the massive number of messages or you turn off tasmoadmin.
PMSL. Fair enough. Wasn’t sure if I had messed something up.
Thanks for your help.
