Repeating laundry notification with time in laundry machine updates
Hi all,
I was looking for a repeating notification with time updates for my laundry because I don’t want it to be in the machine for too long or it will smell. Couldn’t find what I was looking for so I made it myself for anyone who is looking for something like this. If you have any improvements, please share.
  • When laundry is done and you are home, it sends: Laundry done.
  • When laundry is done and you are not home, it waits till someone is home and sends a notification: Laundry done at (time), in the laundry machine for (time in laundry machine).
Both will repeat as long as someone is home and include updates with time in laundry machine. The notifications will stop when no one is home since you can’t do anything about it when you’re not at home.
You have to have some sensor obviously to let HA know your laundry is done. Use that sensor as your trigger in the first automation.
I have a doorsensor on my laundry machine that turns of the automation but you can manually turn it off if you don’t have such a sensor.
Here’s everything you need:
configuration.yaml:
input_datetime:
  laundry_done:
  has_date: true
  has_time: true
input_boolean:
  laundry_done:
  friendly_name: Laundry done
  initial: off
laundry_notification_timer:
  name: Laundry notification timer
  duration: 900
  sensors:
    laundry_done_time:
      friendly_name: Laundry done time
      value_template: >
    {% set hours = (now().timestamp() - states.input_datetime.laundry_done.attributes.timestamp)|timestamp_custom('%H',false)|int %}
    {% set minutes = (now().timestamp() - states.input_datetime.laundry_done.attributes.timestamp)|timestamp_custom('%M',false)|int %}
    {% if hours > 0 %}{{hours}} hour{% endif %}{% if hours > 0 and minutes > 0 %} and{% endif %}{% if minutes == 1 %} {{minutes}} minute{% elif minutes > 1 %} {{minutes}} minutes{% endif %}
      entity_id: sensor.time
automations.yaml:
- alias: Laundry done
  initial_state: off
  - platform: trigger
    entity_id: sensor.laundry_machine
    to: 'done'
    entity_id: input_boolean.laundry_done
  - service: input_datetime.set_datetime
    entity_id: input_datetime.was_klaar
    data_template:
      date: "{{now().timestamp()|timestamp_custom('%Y-%m-%d')}}"
      time: "{{now().timestamp()|timestamp_custom('%H:%M')}}"
  - condition: state
    entity_id: group.all_devices
    state: 'home'
  - service: notify.notify
    data_template:
      title: "Laundry machine"
      message: "Laundry is done."
  - service: timer.start
      entity_id: timer.laundry_notification_timer
- alias: Notification when coming home
  - platform: state
    to: 'home'
  condition:
  - condition: state
    state: 'on'
    data_template:
      message: "Laundry was done at {{states.input_datetime.laundry_done.attributes.timestamp | timestamp_custom('%H:%M')}} and has been in the machine for {{states.sensor.laundry_done_time.state}}."
- alias: No notification when not home
  - platform: state
    to: 'not_home'
  condition:
  - condition: state
    state: 'on'
  - service: timer.cancel
- alias: Repeat laundry notification
  - platform: event
    event_type: timer.finished
    event_data:
      message:
            "Don't forget to take out the laundry. It has been in the machine for {{states.sensor.laundry_done_time.state}}."
- alias: Laundry out of machine
  - platform: state
    entity_id: binary_sensor.laundry_machine_door_sensor
    to: 'on'
  - service: input_boolean.turn_off
Is there any reason you didn’t use the alert component?
I haven’t actually used it yet so am not sure if you can enable/disable it based (in your case) on someone being home.
My main problem with that component is I have different messages for different scenario’s. Probably could be done with templates but I liked this way better.
This is exactly what I wanted :slightly_smiling_face:
I still tweaked the sensor a bit for a nicer output (hour/hours):
  sensors:
    laundry_done_time:
      value_template: >-
        {% set hours = (now().timestamp() - states.input_datetime.laundry_done_time.attributes.timestamp)|timestamp_custom('%H',false)|int %}
        {% set minutes = (now().timestamp() - states.input_datetime.laundry_done_time.attributes.timestamp)|timestamp_custom('%M',false)|int %}
        {% if hours == 1 %}{{hours}} hour{% elif hours > 1 %}{{hours}} hours{% endif %}{% if hours > 0 and minutes > 0 %} and {% endif %}{% if minutes == 1 %}{{minutes}} minute{% elif minutes > 1 %}{{minutes}} minutes{% endif %}
And as I consider that my laundry is done if my washing machine is in standby (i.e. < 30 W) since 15 minutes, I changed the first automation as follows:
  - platform: state
    entity_id:
    - sensor.washing_machine_state
    to: Standby
    for:
      hours: 0
      minutes: 15
      seconds: 0
  condition: []
    data: {}
    data_template:
      date: '{{now().timestamp()|timestamp_custom(''%Y-%m-%d'')}}'
      time: '{{(now() | as_timestamp - (15*60)) | timestamp_custom(''%H:%M'', true)}}'
      entity_id: input_datetime.laundry_done_time
  - condition: state
    entity_id: group.somebody_home
    state: home
  - service: notify.alexa_media
      message: The laundry is done since {{states.sensor.laundry_done_time.state}}.
      - media_player.living_room
        type: tts
    data: {}
