Replace Delay with Timer
Hello
I have a Script to cool the house down for 30 minutes then turn off the HVAC’s. I have been using a Delay to achieve this in my Script but would prefer the restore functionality of a timer. When I disabled the Delay and used a 30 minute timer it ran the script without waiting 30 minutes. Could someone provide some guidance on where I’m going wrong?
Thanks in advance
Here’s the yaml…
alias: AC Blast
sequence:
  - if:
      - condition: state
        entity_id: binary_sensor.workday_sensor
        state: "on"
    then:
      - service: climate.turn_on
        data: {}
          entity_id:
            - climate.device_0279b3
            - climate.device_0276f8
            - climate.device_02731d
            - climate.device_02786c
      - service: notify.notify
          message: A/C Blast commencing
        enabled: true
      - delay:
          hours: 0
          minutes: 30
          seconds: 0
          milliseconds: 0
        enabled: false
      - service: timer.start
        metadata: {}
          duration: "00:30:00"
          entity_id: timer.a_c_blast_timer
        enabled: true
      - service: climate.turn_off
        data: {}
          entity_id:
          message: A/C Blast done!
        enabled: true
    else:
        data: {}
          entity_id:
        enabled: true
      - delay:
          hours: 0
          minutes: 30
          seconds: 0
          milliseconds: 0
        enabled: false
        metadata: {}
        enabled: true
        data: {}
          entity_id:
        enabled: true
mode: single
icon: mdi:air-conditioner
You can post the source inline by surrounding it with three backticks (```).
Your code starts the timer and then turns off the switches. That’s not how timers work - you need another automation that responds to the timer.finished event, and turn them off in that.
Here is your code from google drive:
alias: AC Blast
sequence:
  - if:
      - condition: state
        state: "on"
    then:
        data: {}
          entity_id:
        enabled: true
      - delay:
          hours: 0
          minutes: 30
          seconds: 0
          milliseconds: 0
        enabled: false
        metadata: {}
        enabled: true
        data: {}
          entity_id:
        enabled: true
    else:
        data: {}
          entity_id:
        enabled: true
      - delay:
          hours: 0
          minutes: 30
          seconds: 0
          milliseconds: 0
        enabled: false
        metadata: {}
        enabled: true
        data: {}
          entity_id:
        enabled: true
mode: single
AC Blast.txt
Displaying AC Blast.txt.
Ok, I’ve split them out as per your advice. What Trigger do I use to associate Timer to Automation to turn off?
Script to Turn HVAC on
alias: AC Blast (Duplicate)
sequence:
  - if:
      - condition: state
        state: "on"
    then:
        data: {}
          entity_id:
        metadata: {}
        data: {}
        enabled: true
        enabled: true
    else:
        data: {}
          entity_id:
        metadata: {}
        data: {}
        enabled: true
        enabled: true
mode: single
Automation to Turn HVAC off
alias: A/C Blast Completed
description: ""
trigger: []
condition: []
  - if:
      - condition: state
        state: "on"
    then:
        data: {}
          entity_id:
        enabled: true
    else:
        data: {}
          entity_id:
        enabled: true
mode: single
Further down in the documentation they have some examples showing how to do it.
Thanks Michael, I’ll keep fiddling. Thanks for pointing me in the right direction.
Not sure I have this right, I’m very confused looking at the logic of the automation.
description: ""
  - platform: state
    entity_id:
    to: "off"
condition: []
  - if:
      - condition: state
        state: "on"
    then:
        data: {}
          entity_id:
      - service: timer.finish
        metadata: {}
        data: {}
        enabled: true
    else:
        data: {}
          entity_id:
        metadata: {}
        data: {}
        enabled: true
mode: single
