Below is a bit long winded. The short version is - has anyone found a good replacement for the AIO method in using stretch lite? and if you have do you mind sharing how or linking to the resources you used?
After a lot of trial and error I’ve been using the AIO on jessie lite on my rp3 for a while and am very happy with it. I’ve tried to do the update process to stretch lite to us python 3.5 but it came back with errors.
I decided to try a fresh install of stretch lite and manually install HA. I ended up getting errors with this spent a while trying to get it up running but continued to get errors after installing the virtual environment. Frustration got the better if me and I decided to try hass.io. That was an easy set up but no ozwcp, having issues setting up mosquitto with tls, no winscp and when I made an error I couldn’t use putty to reboot easily means another long learning process I don’t want to have to go through. I spent the day on this and am back to using a backup image of my older version for now. Any help/suggestions appreciated.
