Replacement for the soon-to-be-depricated "Uptime"?
At my last upgrade, I got
The Uptime YAML configuration has been removed
This stops working in version 2022.12.0. Please address before upgrading.
I use this integration a lot, mainly to see of any ESPHome sensors have gone offline.
Is there a recommended alternative integration ?
(I searched around but I’m far from proficient with Home Assistant)
Any recommendations are greatly appreciated,
thanks,
/chrisV
The uptime sensor is still available. You just need to configure it via the UI instead of yaml.
@finity Thank you for your quick answer
Can you elaborate a bit please?
I see this:
But what do I need to configure ? AFAICS, there is nothing to configure. I can add the sensor to a Dashboard, but that seems to be it.
Would it be sufficient to remove the definition from my configuration.yaml ?
pardon my ignorance,
chrisV
Yes.
