It’s seems like my tusty Tellstick Duo has decided to stop working, it still sends out signals but it’s not receiving input from sensors.
I already have a Z-Wave gateway, the plan is to move away from 433 in the future but it’s costly so it will happen over time.
I’m looking for a gatewat that can can read inputs, and that is compatible with HA, Tellstick Zlite V2 is an option, still it has more functions than i need, if there’s a cheaper alternative I’m all ears, external antenna option is most likely needed.
Doesn’t even really require soldering, although that would be better. I have mine setup using dupont wires and stuffed in a little plastic project box with a hole for the usb cable. It is running the mlatest version of Tasmota and works great.
