Replacing old rocker switches
Hi all,
I am looking to replace a 1 gang (non smart) light switch.
Although I thought it would an easy task seems it is not.
What the current status is: A simple rocker switch that controls a lamp at the front door.
What I am trying to do: keep the current functionality (open and close the lamp with the rocker switch from within the house) but also control the lamp from outsite the house with an rf 433 remote that I already have, and later have home assistant add more fuctions to it like open the lamp based on sunset etc
What solution I had in mind: change the old rocker switch with an new rocker switch that has also a standalone rf module (and optionally a wifi module ) attached to it.
And here begins the problem. Living in europe I cant seem to find such a switch. I found some sonoff switches that are touch only. I am googling and searched in the forum also but have no luck so far.
Could anyone please help?
Kind Regards
You have the option of continuing to use the existing switch and putting a device like a Shelly PM1 behind the switch. This will allow HA control, as for the RF you will have to have a separate receiver device that could go to another item like a shelly anywhere in your house and use it to trigger an automation for that light.
