I got a Linktap to control my sprinkler system at home. I am trying to replace the functionality of it so i can control everything within home assistant and not have to bounce between the 2 apps.
i was able to schedule the watering. What i am missing is how to check to see if it is raining, then not run the automation if it is. here is a screenshot from Linktap. Any help would be much appreciated.
You’ll need that information in HA. Either via a weather integration or sensors outside your house. If it’s a weather integration with an hourly forecast, I can help you build a template. Otherwise there’s not much you can do.
thanks for this! so then i would just put this in my sprinkler automation.yaml? Would it check the condition before each time i have in the automation?
alias: GrassSeeding
- platform: time
at: "05:00:00"
- platform: time
at: "08:00:00"
- platform: time
at: "11:00:00"
- platform: time
at: "14:00:00"
- platform: time
at: "17:00:00"
- platform: time
at: "20:00:00"
condition:
- condition: state
entity_id: input_boolean.seeding_grass_plan
state: "on"
- service: switch.turn_on
entity_id: switch.ad3f9228004b1200_water_switch
ok will have a look. would it be able to run the automation unless there was more than 3mm in the last 12 hours or the next 12 hours? or do you think it would be easier to just check condition, and if it comes back as rainy, don’t run?
To check past information, you’d need to jump through hoops. You’d have to make a template sensor that takes predictions and stores them. Then you’d need to make a statistics sensor that sums up the history for the past 12 hours. Then you’d make a condition that looks at the “history” sensor.
will do, just on phone right now. i am not sure i re-loaded the automations though. does that template just make sure that there is less than 3mm of rain for the day?
