Reply box corrupt?
On this site, as of yesterday, now when I reply to a post, the reply box goes off the screen, I have to switch to desktop mode then pinch zoom out to see the whole box, there’s a blank box on the right, and the screen is too small, unreadable
I’m using a Samsung s24 and apple 16
same on both. no changes to mobile settings. all other sites are fine
I do not think it is your device.
I add issues with that exact same post on my workstation.
Something in that post is making the forum code act up.
It is any post,reply.
No problem here.
You are not using any network wide software like AdGuard of Pi-Hole?
nope, I’m using Samsung S24 on mobile data so no LAN impact, and on WiFi LAN. I’m also using an Apple 16. So two devices, two different data connection methods, same result, was working fine last time - I would say last Thursday was the last time I posted replies prior to noticing this.
TBC: this has nothing to do with the mobile app so I moved it.
Maybe/probably, as Wally stated: it’s because of that particular thread (and it’s content) that is not properly rendered.
Remove your signature and the problem will be fixed.
The points go to… :+1:
It makes sense!
Absolute :star: you … that’s fixed it. Thank you
