I have setup some Philio pan06-1b (gen5), it seems that the report back function is not “optimal” when changiing the physical switch. This seems not be able to report multichannel so it cant report individual state of this dual relay at the same time.
As I understand it you have the choice that it will report that “something” has happen on relay 1 or 2 or only 1, or only 2.
It sets up switches where switch 2 and 3 is the relays and switch 4 is the reported state. so switch 4 goes on if relay 1 or relay 2 is flipped.
like this =)
i manual flipp both relays to “on”,
outcome:
switch.badrum_switch off node_id: 6
switch.badrum_switch_2 off node_id: 6
switch.badrum_switch_3 off node_id: 6
switch.badrum_switch_4 on node_id: 6
State is reported back that one or bot of the relays is activated as seen on the value of switch 4.
tried to do some polling at least to have some sort of workaround (conf below) but that seems not to work.
So, does anybody have a solution of above or a super great workaround or should i just skip the dual relay and just use it as a single (bad but at least I know the state on one lamp…)
Conclusion, I would really like to have some help =)
It’s an old topic, but still actual. I bought a couple of these and discovered that I did not get a state report back when switching physisal. Documentation says there is an option to configure whet switch should report using parameter 31, however the options ins de Home assistant UI differ from ZWave JS. In Zwave JS I could select either:
Selected Relay
1 Relay 1
2 Relay 2
3 Relay 1+2
in Home Assistant parameter 31 only gives these options:
Send Report from endpoints
Enable
Disable
It still is a bummer that these devices cannot report both switches individually
